P
project1g
Ok, well heres the story... About 2 years ago i got me a 99 GS spyder, hoping nothing would go wrong but knowing after my 1g that something always goes wrong... Somehow or another the 2.4l SOHC would never go back into correct time no matter how many times I lined it up with the crank and the cam... SOOOO found me a 1400 dollar 95 GST with a 97 harness... Baught it and since there was a salvaged title on it I stripped the harness and motor out and used my friends 97 GST ECU in trade for the 95 EPROM that was in there (should have just sold it) That motor lasted for all of about ... 18 hours untill I was heading to work and the number 4 cylinder exploded...
Heres where I'm at now...
Reman motor
3g lifters
All new internals
If I'm not mistaken 258/258 cams (according to what I ordered(mild cam))
Balance shaft elem. JAM
ARP head studs
New Ebay 16g knockoff
New Exedy stage 1 clutch and flywheel
3 In. exhaust (unknown band)
And a few other things...
Anyway when I installed the motor before Iturned it noticed the motor was 180 degrees out of time.. Fixed that.
Forgot to put timing cover on..
Fixed that
***** Time to start...
Spark plugs are fuel fouled...
Injectors stuck open
Got it to start... Drove it for about 20 minutes easy as hell..
Wastegate got stuck closed on the radiator fan.. Head gasket.
Replaced that
T25 turbo found from friend
Replaced
Drove for about ... 200 miles
Coolant in oil
Checked head gasket and head
Perfect
Upon inspection turbo had a crack in the core...
New ebay 16g
EvoIII OFH ...
now having trouble mounting the oil cooler...
Now I'm wondering if I should just wait and buy the actual OFH for the 7bolt 4g63..
Or if i should just stick it out and fit the cooler on..
Anyway, The only pictures I have are the ones in my profile.. Nothing really project related..
Just putting a journal post up so people can know whats goin' on with me..
If anyone has some good mouning tips on that External oil cooler hit me up
I've been lookin' on the site and it just shows AFTER they have them mounted not really the whole process of brackets and stuff..
Anyway,
Happy Easter
and
Happy DSMing
Thanks
Dylan
Reman motor
3g lifters
All new internals
ARP head studs
Fixed that
Replaced that
Replaced
Coolant in oil
Perfect
New ebay 16g
EvoIII OFH ...
Anyway,
Happy Easter
and
Happy DSMing
Thanks
Dylan
