E
ezz-e
Well I have decided that it is time to raise the power on my GVR4 setup. I’m Going to be upgrading from the stock turbo to a holset hx35. I will be using the original holset housing and having a custom turbo manifold made to make sure it fits my engine bay correctly. Some other things i will be doing is swapping to a Honda civic aluminum radiator and some ARP Head studs with some cam's thrown in there. Well Here are some photos of the engine and what I Have to start with.
Pics of the part's will come soon also...
