D
DSMer541
Over the years of slowly building this car up, it's finally getting close to were I want it. My goal was to make as much power as I can on pump gas and a 16g turbo. I have not yet got it on a dyno to know for sure what its making for power, last time I went to the 1/4 mile track I had a bad day.... starter went out and my punishment intercooler was getting heat soaked, and I ended with a disapointing 12.7@110... I know this car has 11's in it, just need to get a few bugs worked out.... I since switched to speed density which made a great improvment in power and consistency, also got a bigger ETS 3.5" pro race intercooler, also helped intake temps dramatically.... hopefully by next track season ( spring of 2012 ) this car will be done and making well over 400whp on pump gas and running 11's on a 16g turbo.... then after that goal is hit, it will be time to up the bar with a 35r turbo or something along that line..... stay tuned.
Block- 2.0L 4G63T
-stock polished crank
-.02 overbore
-8:1 Wossner Pistons
-Eagle rods
-Clevite 77 bearings
-ARP head studs / rod bolts
-balance rotating assembly
-Balance shafts eliminated ( FFWD kit )
Cylinder Head- Jackson Auto Machine stage2
-CC ported & polished, and nifed
-Jam dual springs & ti retainers
-bronze guides
-lowboy stem seals
- +1mm ss valves
-HKS 272 cams
-OBX adjustable gears
-Gates timing belt
-Mitsu MLS head gasket
Turbo/Intake/Exhaust setup
-MHI Evo III 16g w/ported inlet
-ETS 3.5" pro race intercooler
-FP exh. manifold
-2.5" ebay SS o2 housing
-3" DP & exhaust w/ magnaflow muffler
-Tial QR BOV
-3" intake pipe w/ K&N filter
Fuel System ( 92oct pump )
-Wally 255 w/ STM re-wired
-PTE 880cc injectors
-Fuel Lab AFPR
- -6an feed & Fuel Lab filter
Engine managment
-ECMLink V3
-Speed density
-AEM Analog wideband
-AEM true-boost
-Omni 4-bar MAP sensor
-GM IAT sensor
Drivetrain
-stock t-case, and 4-bolt rear
-Shep stage 3 trans w/ TRE 4spider center diff.
-XTD stage 4 clutch ( 2,300pp, solid 6-puck disk )
-Fidanza aluminum flywheel
-steal braided clutch line
-solid shifter bushing
-Torque sloution front motor mount & prothane inserts on other mounts
Suspension/Brakes
-3000GT SL front bakes (dual piston calipers)
-Steal braided brake lines F&R
-stock struts/springs
-17" eagle alloy wheels
-Champiro HPZ 235/45 tires
Block- 2.0L 4G63T
-.02 overbore
-Eagle rods
-bronze guides
-lowboy stem seals
- +1mm ss valves
-HKS 272 cams
-Gates timing belt
-FP exh. manifold
-Tial QR BOV
-Fuel Lab AFPR
Engine managment
-ECMLink V3
-Speed density
-AEM true-boost
-GM IAT sensor
Drivetrain
Suspension/Brakes
