Complete Interior Rebuild In Progress!!! Continued Paint Prep!
F
Flash
I bough the paint and everything else. I continue to grind away at the seam sealer. There is a lot of dust. Prepping with red scotch brite pads by hand (this sucks). As you can see, all the sound deadening and seam sealer is removed! That was by far the most time consuming part, besides removing everything from the interior!
